DECEMBER 16, 2025
AUDIO BREWERS AUTOMATES AMBISONICS DECODING IN YOUR PRO TOOLS SESSION
Screenshot of Audio Brewers 'ab Decoder HOA Express' Ambisonics plugin in Pro Tools
Audio Brewers introduces 'ab Decoder HOA Express' - an Inner Circle Reward avalable to all Pro Tools Artist, Studio, and Ultimate customers with active annual subscriptions and perpetual upgrade plans. With 'ab Decoder HOA Express', you can now effortlessly decode your Ambisonics signals by simply inserting the plugin. Whether you’re working in Stereo, 5.1, or Dolby Atmos, 'ab Decoder HOA Express' gives you a seamless way to use your Ambisonics signals in any project - immersive or not. No setup, no configuration, no hassle.
If you’re new to Pro Tools, you can learn more and download the free 30-day trial here.
Screenshot of Audio Brewers 'ab Decoder HOA Express' in Pro Tools Dolby Atmos session
HIGHLIGHTS
With 'ab Decoder HOA Express' you can:
  • Decode any 1st, 2nd, and 3rd Order Ambisonics signal (1OA, 2OA, 3OA).
  • Decode to Stereo, 5.1, 7.1.2 Speakers layouts.
  • Fine-tune the volume of each speaker pair.
  • Control the LFE Loudness (when available).
'ab Decoder HOA Express' was created with one thing in mind: automatic decoding of Ambisonics signals with no set-up required—perfect for people looking for fast results, but that's not all !
THE GATES TO AMBISONICS
'ab Decoder HOA Express' is a simplified version of one of our decoders - if you are looking for more Speaker Arrays, further flexibility, higher-order support, or even to Upscale your Ambisonics signal to increase its spatial definition, our collection of decoders should cover all your needs!
Image of Audio Brewers Encoder Comparison Chart
If you are looking to encode your discrete signals (Mono, Stereo, Quad, 7.1, and so on) into Ambisonics to easily bring them into your immersive projects, our 'ab Encoder' should assist.
Screenshot of Audio Brewers 'ab Encoder' plugin in Pro Tools
Learn more about ‘ab Encoder’ at https://avid.audiobrewers.com.
THE 'AUDIO BREWERS' ECOSYSTEM
Once your signal is in Ambisonics, any Ambisonics effect you insert will work three-dimensionally and will be speaker-agnostic, meaning that you will be able to decode it to ANY speaker array that exists and will ever exist.
At Audio Brewers, all our plugins work natively in Ambisonics, meaning that whatever you do, will always work in any of your projects. Whether you work in stereo, Dolby Atmos, or any format available, Audio Brewers plugins will always process your sound natively in Ambisonics.
Screenshot of Audio Brewers plugin ecosystem
Learn more about other Audio Brewers plugins at https://avid.audiobrewers.com.
AVAILABILITY
'ab Decoder HOA Express' is available to all Pro Tools Studio and Ultimate customers with active annual subscriptions and perpetual upgrade plans. You can download 'ab Decoder HOA Express' through Avid Link or from your Avid Account.
